Error 3 suggestions?
I've got a S5 that will no longer start and complains about error 3 instead. I believe that this is meant to mean that the wheel are not down but they definitely are.
I have moved the s5 to a new location, checked the wheels and also done a reset with no luck. Any other suggestions what to look at?
  • I've got a S5 that will no longer start and complains about error 3 instead. I believe that this is meant to mean that the wheel are not down but they definitely are.
    I have moved the s5 to a new location, checked the wheels an https://9apps.ooo/ d also done a reset with no luck. Any other suggestions what to look at?
    issue got solved
PristoMiky
