Large house cleaning - S5 does not finish
From what I saw in a response to another customer, the Roborock vacuum will not resume cleaning four a fourth round. For example:
  1. Cleaning activated when the vacuum is at 100%, robot will clean to 20% (round 1), dock, and then charge back to 80%.
  2. Robot will clean to 20% (round 2), dock, and then charge back to 80%.
  3. Robert will clean to 20% (round 3), dock, and then charge back to 100%.
  4. Cleaning stops - no round 4 - EVEN IF there are mapped areas that are not complete (this is our scenario).
First - is this correct in how the software is supposed to work? I have the Roborock S5 (model S501-01).
Second, what is the workaround for this as our house is big enough where we need a fourth round? Can we up the charging value to 95 or 100 before Roborock starts round 2 and 3? A manual workaround would obviously be to block an area of the house, let it finish everything but the blocked area, let it recharge, then have it do the blocked area - a bit frustrating to have to do that when one would think a software fix would allow the robot to perform unlimited cleaning rounds until it was done.
Finally, it also sounds like there is no way to have the vacuum finish a job by manually starting the cleaning process before 80% charge. For example, say there was a smaller space where the vacuum had like 10% floor area left to vacuum after the first round (battery 20% and Roborock docks). Is there no way to restart the vacuum when the battery was at say 50% just to finish the last 10% instead of having to wait until 80%? This obviously is not our main issue as Roborock will not even finish one full go around of our entire floor, but I am just curious as to the answer to this question.
Thanks!
  • From what I saw in a response to another customer, the Roborock vacuum will not resume cleaning four a fourth round. For example:
    4. Cleaning stops - no round https://omegle.onl/ https://xender.vip/ 4 - EVEN IF there are mapped areas that are not complete (this is our scenario).
    thank you my issue has been solved!
LavenderBirch
