Power button - Red blinking
Hi team,
my roborock is unable to charge beyond 20% and the power button keeps flashing red when I try to charge it. I have tried to leave the roborock to charge overnight and clean the contact points with rubbing alcohol but that didn’t work as well. Can you advise what I can do? I am not able to update my firmware as the battery remains less then 20%.
Appreciate the help.
Cheers!
  • 1. If you have wiped charging contacts, could you send us pictures to show them?
    2. Please check if the dock charger is working or not.
farahnad
