I am using Roborock S5 Max and Roborock Android app. We can select cycles for Room or Zone cleaning from the app. But even if i select 2x Cycles it uses the same route for cleaning. Roborock finds the most efficient direction for fastest cleaning. But it uses same direction in every clean. Especially cleaning the carpets using cross routes provides better cleaning.
I want a multi directional cleaning feature. If i open and clean a room or zone once nothing will happen, it will clean the area like normal way. But if i select multiple cycles for cleaning it will change its directon in every cycle. For example if it cleans the room in horizontal lines in first time, it must clean the room vertical in second time. It can spend more time and more battery because it will use shorter straight lines in the second turn but it is not important for me. Using cage pattern will provide better cleaning.
I added a sample screen shot.
Great idea, this would clean my carpets better and does not leave that occurs marks due to cleaning same direction every time.
@S5MaxUser My S5 Max sometimes do it.
