Hello, I accidentally used liquid other than water in my Roborock Q8 Max. Since then, no water is dispensed during cleaning. Could you advise how to resolve this? Also, could you help me identify the air vent on the tank? Thank you in advance for your support.
For anyone wondering, here is how I managed to resolve the problem: There was a blockage in the last small tube before the water exits through the two small water outlets at the bottom.
I was unable to remove the blockage from the top, hence, I used a syringe to inject vinegar into the small water outlets at the bottom. Then, I used some rubber to seal the syringe and prevent any air from exiting / entering from the outside and pumped more vinegar into the small outlets. This created enough pressure to push the blockage through the tiny tubes and free them.
Hope this helps someone. Also many thanks to the Roborock customer service who has been very supportive. Cheers
