Manual map selection
it would be great if you could add the possibility to manually choose the map the robot uses to clean. This would add the possibility to use multiple maps of the same floor with different customised cleaning option without the need to change "on the fly" eache time the cleaning option (for example setting the map to activate the deep washing mode in some rooms).
At the moment I think this is the principal lack of your geat app.
Geppo
