S7 frequent "main wheel jammed" and nav errors
So i recently acquired an S7 to replace my Roomba i7 and so far I really like it, but I'm noticing that almost once every clean the s7 will stop and give me an error message to clear the main wheels, and everytime I check nothing is blocking them. About 90% of the time I can just resumet he clean and it takes off and finishes with no problem. Oddly the bot ran fine for the first week or so and now it's doing this.
Just wondering if anyone has had this before and if so how they fixed it? It's seemingly random, usually just in the middle of a room. I've also noticed the bot will occasionally go facing into a corner and then say it's stuck. This one is irritating because resuming the clean won't fix it, it'll just spin in circles unless I physically move it or remote control drive it backwards.
Hoping these are just some software bugs to be worked out as otherwise the bot works so much better than my roomba ever did.
  • what solved your issue?
  • Hi, we apologize for the inconvenience caused.
    1) When the issue occurred, may I know where the robot is? Is it on carpet?
    2) Could you please check if there's anything stuck inside the wheel when the issue occurs?
    3) Please try and upgrade the firmware of the device to its latest version.
  • I am experiencing the same thing currently. It was on carpet when i initially received the wheel jammed error. I picked it up and didn’t notice anything jammed or stuck in the vacuum. I have since moved it to hardwood (which 85% of my house is) and it just says repositioning every 15 seconds for like 3-4 mins all while slightly moving forward, backwards, and side to side but it essentially stays in the same place the entire time. Then after about 4 or so mins of “repositioning” it just stops and says wheel jammed and the light on the top of the vacuum turns red. Is there a fix for this yet?
    RR_SupportStaff Member12/27/2021      00:36
    @BOFA:
    Hi, thanks for your reply.
    According to your description, it seems that there's something stuck inside the wheel.
    You can press the wheels to see if they can depress and rebound freely and turn them to see if they can rotate freely.
    If nothing is stuck inside and the wheels move freely, you can also try the method below:
    https://youtu.be/MiBkw_lcTF8
    DMFA
    DMFA10/27/2022      16:11
    I had the same issue and this worked perfectly thank you
    RR_SupportStaff Member10/29/2022      17:19
    @DMFA:
    Hi, thanks for your updates! For further help, feel free to contact us!
  • My S7 keeps saying the wheels are jammed. I moved the wheels up and down and pushed it around for 10 seconds like an eraser as suggested. Any advice?
    RR_SupportStaff Member09/09/2023      09:24
    @Suuz:
    There might be something wrong with the device itself.
    Would you please contact us at support@roborock.com(if you are in EU, contact support@roborock-eu.com)so that we can better assist?
micheblea83
