Invisible wall vs no go zone?
Hi, what is the difference between using the invisible wall compare to a no-go zone. For example I have a balcony which is slightly lower so I don't want my robot to go there, so do I use the invisible wall or a no-go zone? Secondly I have sofa that the robot can fit under, but it kind of gets stuck so it comes back out. Do I use invisible walls around the sofa or do I use a no-go zone on the sofa in the map. Roborock S7 btw.
    You can think of the no-go zone as an area where you've put 4 invisible walls. For invisible wall, it's like a wall. The robot won't try to cross it. For no-go zone, the robot won't enter the zone.
    For example, the balcony, I think the invisible wall is fine because normally there's only one way to balcony. For the sofa, not sure how it's placed and look like. If there are multiple angles the robot can go under the sofa, maybe you can set a no-go zone. If you just put the invisible wall, the robot may be blocked in one way, but there's still another for the robot to get under.
RockyPeli
