Error 118 right odo
Error 118 right odo
I got S6 Roborock since January 2020 and it just stopped working today with Error 118 Right ODO. Followed the instruction to reset and done so several times, but still go back to the same error message.
    please try the method below:
    https://youtu.be/MiBkw_lcTF8
    Notice:
Nicolas Hurtado
