Multi-floor glitch on S5Max
My S5Max has maps for two floors and is set on Multi-level in the Roborock app, but recently it started showing only one map on start-up (the last one used) although previously it showed the option of both maps. I now have to go into Manage Maps and Restore the other floor map when I change floors. Its a nuisance rather than a big problem but I wonder why it has changed. I got the recent firmware upgrade to 01.13.28 but its the same. Any suggestions please?
  • My S5Max has maps for two floors and is set on Multi-level in the Roborock app, but recently it started showing only one map on starthttps://omegle.onl/ -up (the last one used) although previously it showed the option of both maps. I now have to go into Manage Maps and Restore the other floor map when I change floors. Its a nuisance rather than a big problem but I wond https://vshare.onl/ er why it has changed. I got the recent firmware upgrade to 01.13.28 but its the same. Any suggestions please?
    issue got solved!
actiopabs94
