Wifi led does not blink after wifi reset
Hi, i have an S5 Max. A few months ago the wifi stoped working. The wifi led indicator blinks only once after the reset, and never lights up or blinks again. After contacting the support i recieved the e-mail attached. The problem is that i moved to outside US and can not send it to repair. Is there anything else i could try to perform remotely? The vacuum is useless if i cant create no-go zones.
regards
  • Hi, thanks for your reply.
    According to your description, it seems that there may be something wrong with the wifi module. Normally, after resetting wifi, the LED light should be flashing slowly.
    We suggest you try and send the device back to our repair center and get it fixed.
ThiagoFRV
