S5 Max disable the wifi
Is there any way to disable the wifi? We own the S5 Max.
  • I'll give myself an answer. If you reset the wifi first and then wait about an hour, the wifi is deactivated.
    RR_SupportStaff Member08/28/2021      08:11
    @SilasP:
    Hi, thanks for your question and answer.
    Yes, that's correct. If the robot's wifi is not paired, the signal will be disable in one hour. Best regards.
SilasP
