Permanent Zones
Permanent Zones
Hey guys,
Im a new S7 owner and our new family member is doing a great job. The only problem is, that I can't define a permanent zone. I want do mark a zone in front of the cat litter, so the Roborock can clean this part of the room every X hours. I don't want to clean the whole room, but the defined Zone disappears after cleaning.
Am I using the app wrong or do you know a workaround?
  • Hey guys,
    Im a new S7 owner and our new f https://1921681254.mx/ amily member is doing a great job. The only problem is, that I can't define a permanent zone. I want do mark a zone in front of the cat litter, so the Roborock can clean this part of the room every X hours. I don't want to clean the whole room, but the defined Zone disappears after cleaning.
    Am I using the app wrong or do you k https://100001.onl/ now a workaround?
    issue got solved
  • Did you say you found a solution to impermanent zones?
KarelSoel
