S5 Error: 106 Left Wheel Open Circuit
Hi, I have a S5 and get Error 106: Left Wheel Open Circuit. I replaced the left wheel assembly and still have the same issue. What's the next step for me to try?
    please try the method below:
    https://youtu.be/MiBkw_lcTF8
    Notice:
    Andy
    Andy05/23/2022      01:30
    Oddly enough, this worked for me. I am wondering why it works and what actually needs maintenance on the robot.
    Jahir
    Jahir07/14/2022      09:00
    Hello
    This method worked for first two instances but now it is not working anymore. The error 106 is not going away. What should I do? Should I replace the left wheel? If so, how to do it?
    RR_SupportStaff Member07/16/2022      15:40
    @Jahir:
    Hi, thanks for your reply. In this case the wheel may probably need to be replaced. But some models may be easy to have the wheels replaced while others may not. May I know which model you're using? If the device is still under warranty, we'd suggest start warranty service because oepning up the robot may void the warranty.
chuck
