Can´t connect to WIFI after Router issues
Hello!
We are using the S7 and it worked fine for 2 months, no issues at all.
But since two days after the internet acted up and we had to reset our router the S7 can´t connect to the Wifi anymore. It says "wifi connection failed, check password"
Solutions that have been tried and that didn´t work at all (on iOS using the roborock and the xiaomi app):
-Reseting the wifi
-Resetin the router again
-tried with the mac adress
-factory reset
-tried over mobile internet (hotspot)
-tried to change the server-location
-pretty much everything that could be found on the internet
Why is this a problem now even though it worked before?
And is there a solution to this?
  • Hello!
    -Reseting the wifi
    -factory reset 192.168.1.254
    https://100001.onl/ -tried to change the server-location
    issue gtt solved
OzelnHaxy
