Room naming in S5 and supported apps
I have S5 (not max) and I would like to use Google voice control for room cleaning. I'm not able to find room naming possibility from my Xiaomi Home app (version 6.11.702). If naming should be under Edit room, I only have there Merge and Divide.
Should Roborock app work with S5 model (I tried but it does not find my S5..)?
Thanks!
  • Hi, the model S 5 only supports Mi Home app connection. Since this model doesn't support room naming feature, so you can not use voice command to let it do room cleaning.
    m_____
    m_____10/07/2021      10:57
    Okay, thanks for information.
    RR_SupportStaff Member10/09/2021      14:59
    @m_____:
    You're welcome~
m_____
