Initially the vacuum became offline & couldn’t ever be reinstalled on the Mi Home App. Howevr, it continued to function with the onboard buttons & remembering the map & dock. Now it has switched off completely & couldn’t be restarted. Checked the battery voltage by removing the same. It shows 15V. Please help.
The vacuum is about 28 months old & was brought from Banggood site for home usenin India.
We apologize for the trouble caused.
Have you docked the robot manually with the charger to check if it could turn on or not?
https://youtu.be/LHupFrt14BE
