One of the wheels of the S5 max was stuck and the robot was unable to operate. What was possibly causing the problem? Do I have to get the wheel replaced? Where can I buy the wheel replacement in Jakarta? Thank you
1) Please check if there's anything stuck in the wheel. You can press the wheels to see if they can depress and rebound freely and turn them to see if they can rotate freely.
2) If the wheel is hard to turn, and nothing is stuck inside, you can also try the following:
please try the method below:
Notice:
https://youtu.be/MiBkw_lcTF8
Notice:
