Last night I attempted to update my S7 and everything seemed fine until it “rebooted”. My phone then showed the unit was offline and now the unit has a rapidly flashing white light. I can’t get anything working, the vacuum didn’t vacuum last night, nothing works anymore. Any ideas or did the firmware brick my unit?
1.12.72 updated to 1.13.20 is what was attempted.
Honestly I think that firmware needs to be rolled back for everyone and maybe should stop getting released. Mine installed fine, but now my vacuum navigates like it’s intoxicated . Making super wide unnecessary turns and skipping whole areas randomly.
I hope your unit isn’t bricked though.
May I know if the robot can respond at all if you press any of the button? Maybe you can send us a short video showing the robot's abnormal behaviour.
We suggest you also factory reset the device to go back to the previous firmware to give it a try.
