Issues with Roborock S7 after update - robot offline
I updated to the latest firmware today and since then am not able to make the robot work.
The update went ok, robot announced that the firmware was installed, but the message in the app said that it failed. I thought that it was some bug of the app and wanted to start cleaning. This didn't work as the app was showing that the robot was offline. I opened the lid and saw the wifi light rapidly blinking. What I have tried so far:
1)switch off the robot and turn it back on - no dice.
2)reset wifi - robot wasn't able to hook up to the wifi, router shows that it is connected though, but neither app, nor robot recognizes this
3) reset cache in the app, remove robot from app and reset wifi - same problem, robot fails to log into wifi and wifi light keeps blinking rapidly. Router shows that it is connected though.
4) same as above plus switching off the 5 GHz network in the router - robot announced that wifi is connected, wifi light stopped blinking rapidly, but the app still cannot see it.
Some other info: account location is in Germany. What I couldn't do, is to change the location to other regions as this option is disabled for me in the account menu. I haven't done full reset either as I don't think it will help, so saving it as a last resort.
Any suggestions would be appreciated.
    We suggest you factory reset the device to give it a try.
    Notice:
    1. Factory reset will disconnect the robot from Wi-Fi. Please re-add it after the reset.
    2. Factory reset will make robot's firmware version go back to the original one. After the reset, you can check for updates to upgrade its firmware to the latest one.
    3. Factory reset will delete all your settings on the device like scheduled cleaning.
    4. Factory reset will delete every single cleaning log including every cleaning's duration, size, and map. The total duration, total times of cleaning, and total size will be still kept there.
  • I just updated and have a same issue, should have not updated...
    SomebodyF
    SomebodyF11/20/2021      21:17
    @SomebodyF:
    I shut it off of a dock, waited 10 min, restarted and its working again.
    RR_SupportStaff Member11/21/2021      15:29
    @SomebodyF:
    Hi, thanks for your updates! Glad to hear it's working now.
    If there's anything we can help with, please feel free to reach out!
    SomebodyF
    SomebodyF12/24/2021      23:53
    It went offline again : (
    I have to manually restart to get it to connect. Dock is located in a good Wifi signal area so I'm not sure why it is not working.
kothor
