Charging problem Roborock S5??
Hi, I have recently come across this problem when charging my Roborock S5.
It starts to charge correctly but after a short period (30 seconds - 3 minutes) it resposition itself by backning out and into the charging station and continues to charge. This repeates a couple of times until it gives an Error 13.
    1. If there're some stains or rust on the charging contacts on the dock or underneath of the robot, please use a piece of cloth moistened with alcohol solution or an eraser to remove them. See attached picture "charging contact".
    2. If you have wiped charging contacts, could you send us pictures to show them?
    3. Please check if the dock charger is working or not.
    https://youtu.be/LHupFrt14BE
    4. Please unplug the charging dock, and leave it there for about 2 minutes. Then please re-plug it and try again.
MatthewWade
