S7 - Separate Docking Station on each floor
Can I put a second charging/dock station on a separate floor of the house?
I saw a similar question for the S5, but wanted to make sure the answer applies to the S7 too. My main AutoEmpty dock is on the main floor near a utility area, but it would be useful to have a second station on the second floor (it sometimes runs out of battery before it finishes the second floor). DO I just remap the second floor from the second dock to teach the robot to return to the second dock when it is cleaning the second floor?
    The following answer applies to S7, and doesn't apply to S5 because S5 doesn't support multiple floor map feature.
    Yes, you can use a separate docking station on each floor. The robot will be able to determine which floor it is on, and use the correpsonding map. You just need to start the robot from the dock, and let it do a round of full house cleaning to map the house. Please don't forget to enable the multiple floor mapping feature on.
Rocky
