A suggestion for roborock dyad
Hi Roborock Community,
I'm a huge fan of roborock products and I bought nearly anything of the latest products in a preorder.
So with the roborock dyad and I need to say that thing is amazing! I have just one suggestion to make it even better.
Can you release side brushes with much more fluff to the edges? Even with the good edge cleaning capability, I have nearly 1 cm of edge that is not cleaned because the brush is so thin. And one more thing is that maybe the brushes have some harder bristles like the multi-surface brush of Bissel Crosswave (Photo attached).
If you would fix that you create the perfect wet cleaner!
Thanks!
This discussion has been closed.
Malli
