Error 105 wheel short circuit
We ve had our vacuum for a little over a year and now we started to get this error. What is the warranty on these and can this be fixed? Please advice.
    You can try the method below:
    https://youtu.be/MiBkw_lcTF8
    Notice:
    If that doesn't solve the issue, please contact support@roborock.com to get further assistance with the warranty.
KC
