S7 How do I change clean settings for zone
How do I change the cleaning setting when zone cleaning, clean now and spot cleaning.
    For zone cleaning and clean now, you can change the suction level real time via the app. See the picture below:
    For spot cleaning, the device is set to clean at max mode with the largest suction strength, which can not be adjusted.
Grimm
