New S7 Purchased - Mopping of white tiles withe dark grout lifts the mop continiously as it goes
FW 2.13.98 (recent)
Carpet Ignore Mode On
Deep Mopping Intense Setting On
This stops it mopping my floors clean in any consistant way
This does not compute :¬)
This has been reported by others redit etc who said it used to work fine on older firmware
    Could you please send us a screenshot of the history cleanup map when the issue happened so that we can understand the issue better?
    suelem
    suelem01/01/2023      22:54
    I have the same problem.
    My s7 slows down and raises the mop when cleaning hard floors, I don't have a carpet. It's like the s7 understands that parts of the floor are carpet.
    The sensors are clean and carpet Ignore Mode On.
    Please help :(
    RR_SupportStaff Member01/12/2023      16:10
    @suelem:
    Have you tried to lower the water flow? It's likely that the robot slipped in the middle of cleaning.
    suelem
    suelem01/13/2023      15:23
    Hello, yes, I already tried to reduce. The problem continues.
madusmacus
