S5 Max cannot connect to Wifi - But it connects to my router
Hello. I haven't used by Roborock S5 Max for a few weeks and when I tried to do it today, it couldn't connect to my Wifi. I thought it was a simple procedure to reconnect, but then the nightmare started.
I tried everything: reset to factory settings, reinstall Roborock App, use a different device, use Xiaomi Mi app, with no luck.
From my router, I see that the Roborock GETS an IP ADDRESS from it, so it does connect to my Wifi and my network. Still, it says cannot connect to Wifi.
I read somewhere that this error might be the robot trying to reach a Roborock server in the Internet. Is it something with my DNS? Which server is it trying to reach? Is it known that some Roborock servers are currently down right now?
PLEASE HELP, I can't use the device I bought.
    Our devices don't support 5G HZ wifi but only 2.4G HZ wifi. If it's 2.4G, please try the following:
    1. Make sure the password of your wifi you've input is correct.
    2. Don't use an android tablet, iPad, iPhone 5 or iPhone 5C to connect the robot as there might be a compatible issue.
    3. If there are special characters like !@#$ contains in your wifi name or password, it's suggested to remove them in the router settings.
    4. The robot doesn't support WEP encryption mode. If your wifi is WEP, change it to WPA or WPA2. You could also try to change the wifi channel.
    5. If you understand the router's setting very well, try to change DNS to 8.8.8.8 in the router's settings page.
    6. Reboot your router to see if it works.
    wrows
    wrows01/02/2022      17:34
    Hello. I already tried all of that. And yes, I also tried to use Google DNS 8.8.8.8. None of that works.
    RR_SupportStaff Member01/10/2022      09:02
    @wrows:
    Would you please try the following?
    The robot could connect to a hotspot from a smartphone.
    To connect to a hotspot, you need 2 smart phones (A and B).
    2. Use phone B to install the app and try to connect the robot to the hotspot sent from phone A.
    Forget about the wifi sent from your router in the whole process.
wrows
