S7 offline will not connect
Went offline one night:
turned off and back on
Went through the procedures to reconnect online -- app sees the roborock wifi but says no internet.
Tried this many more times
Reset the S7
still would not connect
cleared app cache
deleted and reinstalled the app
Have done this over the last 3 days thinking maybe the problem was the online syncing
Took this to a new 2.5 wifi and tried to connect still the same (wanted to eliminate local wifi issue)
Don't know what to do next. I have read the many other offline issues on the support but none of them solved my issue.
Thanks,
Daniel
Firmware: 02.13.98
attached is a
picture of roborock numbers
https://drive.google.com/file/d/1sCEUxJtSdB48oSC5AagNiCBRKdR3-GI1/view?usp=sharing
    In this case, we suggest you try the following:
    1. Please reboot the robot first.
    Note: Move the robot off the dock, press the power button for 3-5 seconds to turn it off/on manually.
    2. Please then delete the offline device and reconnect it.
    1) Press and hold the offline device on the app and then remove/delete it.
    2) After that, please reconnect it to the home wifi.
    If that still doesn't work, please try a hard reset on the robot.
    If none of those solves the issue, please download another app called Mihome to try the connection one more time.
    Tiff
    Tiff07/20/2022      00:59
    Hi I have same issue and did follow the instructions as above but it still would not connect. Help pls.
    RR_SupportStaff Member07/22/2022      09:05
    @Tiff:
    Hi, thanks for your reply. In this case, we suggest you try a factory reset on the robot to have a try:
    The instructions are as follows:
Hbuonline
