Robock S4 Internal Error
My Roborock S4 continues giving me Internal Error #108. I have restarted the cleaner many times but the problem persist. Also the cleaner keeps saying to "check the filter as it might be wet or blocked. Fan speed has been temporarily lowered. It will be automatically restore after is cleaned". I replaced the filter by a new one and the same message continues. I have also deleted the map to see if that will help but both errors (internal error #108 & wet filter) remain. The cleaner will not operate for more than 6 min before prompting for error #108. Please advise any additional steps to fix this issue. Thanks.
    please try the method below:
    https://youtu.be/MiBkw_lcTF8
    Notice:
    Fian
    Fian03/05/2023      19:50
    I have same trouble with my Roborock S2, that always giving me the error 108 on right ODDO, actually Im already exchange or buy new one set...but always get the same trouble, this is make frustrated... I'm assuming this trouble from software updates.
  • I have same trouble with my Roborock S2, that always giving me the error 108 on right ODDO, actually Im already exchange or buy new one set...but always get the same trouble, this is make frustrated... I'm assuming this trouble from software updates.
    RR_SupportStaff Member03/16/2023      13:23
    @Fian:
    Hello, thanks reaching out.
    The issue is usually a hardware issue rather than software. If the above mentioned troubleshooting doesn't resolve the issue, there may be something wrong with the wheel. We suggest you get in touch with our support team at support@roborock.com to get further assistance.
JE
