s6 MaxV issue
s6 MaxV issue
Why does the app say my robot is offline when it's not? This just happened, I was using the robot and app two days ago. Using updated app. I've tried to turn the robot on and off and have also tried re-pairing with the app. Help!!!!
    Please observe if the wifi indicator light is solid on or flashing.
    If it's flashing, it means the device is disconnected. In that case, we suggest you try the following:
    1. Please reboot the robot first to see if the device can be back online automatically.
    Note: Move the robot off the dock, press the power button for 3-5 seconds to turn it off/on manually.
    2. If it's still offline, please then delete the offline device and reconnect it.
    1) Press and hold the offline device on the app and then remove/delete it.
    2) After that, please reconnect it to the home wifi.
    Ansj
    Ansj04/10/2022      19:03
    I have the same problem.
    But i cant find the unit When i reset it.
    please advice!
    is your problem fixed yet?
    RR_SupportStaff Member04/12/2022      12:30
    @Ansj:
    Do you mean the robot coulnd't be found by your phone? In this case, you can try a round of factory reset and then try to get the device reconnected. Here's how you can do the factory reset:
cym
