Discovered both Home & Power buttons blinking on my S5 Max and no longer accessible via Android app so after doing WiFi rest (didn't help) I had to do full reset of the device. Following full reset, I re-added it to my application but all my maps stored there are now lost. How to get the maps back?
Also, there is a firmware update but it is stuck on 0% for a while and there is no option to restart this process.
Thanks.
A factory reset will erase all maps and currently there's no option to restore deleted map. You may need to start a round of full house cleaning to remap the house.
For the firmware update issue, may I know if it's stuck at downloading or installing?
I've tried a firmware update the following day and it worked. I had to remap whole apartment.
What is the "Map Saving (Beta) feature in the app for? I always thought that it allows the map and other data to be retrieved?
Hi, thanks for your reply. Once the button is enabled, it means the map will be saved. In the next cleaning session, the robot will use the saved map rather than creating a new map. If it's disabled, the robot will create a new map every time it cleans.
