Roborock S6
I am getting the same error message. Keep getting an internal error with reference to the left wheel. I reset to factory settings. I cleaned the wheel to make sure it didn't have any debris. It will run for 15-20 minutes then has the internal error. In the app, it lists the error as follows, "Internal Error - Malfunction due to an internal error.
    please try the method below:
    https://youtu.be/MiBkw_lcTF8
    Notice:
Misty
