S6 maxv mopping behavior suggestions
Hi, i’ve got a s6 maxv and in the app there’s an option to increase the suction power when it detects its on a carpet. Why not use this setting to also switch off the mopping water?
Also, i have no-mop zones set up and currently, it avoids the no-mop zones completely when i have the mop tank installed. Why not just switch off the water and run the vacuum only when entering a no-mop zone? Alternatively, why not just ignore the no-mop zone when its running a clean cycle with the water setting set to off?
Jotsy
