Roborock s50 stop working when battery is on 70%
Recently the robot stops working after the battery reaches 70 percent. It just turned off.
I purchased a new battery and replaced it but the problem returned after several sessions
Is it caused by a damaged battery? Is it possible that the new battery is also faulty?
  • RR_Support
    RR_SupportStaff Member10/29/2022      17:15
    @divur1:
    Hi, thanks for reaching out. The issue you faced may not be solved in a short answer. We hope we could work with you to locate the cause and address it. Would you please contact us at support@roborock.com(if you are in EU, contact support@roborock-eu.com)so that we can better assist?
    divur1
    divur110/31/2022      08:09
    Thanks, I contact support@roborock-eu.com. hope to get assistant soon
divur1
