S5 max battery discharging immediately
S5-Max
Problem: battery discharges immediately after it is off the dock.
the last time I used it (yesterday) I notices it was leaking water (which after a partly disassembling turned out the jets were blocked)
I
- let it run out of water took the tank off and then vacuumed a bit more (to let it dry) until the battery was low enough for it to return to the dock by itself.
- let it charge to 100%
- took it off the dock and cleaned it (holding it over an edge so i didn't have to turn it up side down in case of any water anywhere)
- put it back on the dock but it claimed it had to recharged. - app said 0%
- waited for a recharge
- sent it to a location (pin and go)
- the moment it is disconnected from the dock it goes to 0%
so either
- the battery (which was fine without much of a difference to when it was new about 2 years ago) went dead just like that.
- the mainboard/charging/power logic is broken.
I did take the battery out and the S5 acknowledged this with an error. So it does detect that whether there is a battery or not.
when I put it back in, it needs to recharge,
when I take the robot off the dock it is dead.
any thoughts?
any idea if I can test the battery somehow outside the S5?
thing is, I am not living anywhere close to a service center or spare parts shop, hence I will have to order things and will be able to pick them up around Christmas.
Ideally I pick up the correct spare (or a new robot)
Thanks,
Axel
