The app thought that my door frame was so cozy that it created a small 4 pixel room that is to small for me to select it by tapping from the map.
I can't get rid of it by merging it back into the room because it's to small for me to select. Is there a some sort of "drop-down list" that can let me select the rooms from there? That way I can remove the accidental room that was created by merging it with the room it is in.
We're sorry for the inconvenience caused. Currently there's no a list avaliable to select that specific room.
To get rid of that room, you can try and press the "Re-split" button. But the risk of doing that will bring the map to the original status and you will need to redivide the map into different rooms.
