Extra room to full map with custom sequance, but doesn't clean extra room with full clean
I thought i did something smart, but can't get it to work. I have a map called "groundfloor". This map contains now 7 rooms. It used to be six. With the map wit six rooms i always had to do a full clean and to clean the dining room fully, i had to do this room twice completely. First outside, then move the seats and do the dining room again to clean under the table.
So my setup now is to add the 7th room and do an custom sequence. So i have a room "dining room" and "dining room table". Sequence is 1st "dining room", 2nd "kitchen", etc. Last room, 7th, is the ''dining room table''. While it cleans the other rooms, i move the seats backwards and i assumed it would clean only the "dining room table" (last room 7) last. But it finisches after room 6.
Current map :
How can i fix this? Or is my thinking wrong?
Frank
