We vist out friends for a long weekend every year, and want to use s7. To help with the cleaning, I pressed the power button to start cleaning. It started to clean but seemed to wonder around after it Cleaned an area. It was like it was searching for the home base. I did not want to map their house because it was a one time run. It burned through the battery really quick. Can this be done or did I do something wrong.
If it's a place it's never been to, it might start remapping.
A possible solution would be to use multiple floor mapping feature and treat it as a new floor and save it as a floor map. Then when you plan to return home, you can delete that map without erasing your current home map.
