The vacuum started getting lost 3 - 4 months ago, so I had to delete the map and start all over.
There is no edit button to click to separate the rooms and/or define what order the rooms should be cleaned in.
What do I do?
Hello, thanks for reaching out. Would you pls send us a screenshot to show the issue?
May I know if the current map is saved? Was the edit/sequencing feature available previously?
