Hello, I just bought a brand new S7 MaxV Ultra vacuum/mop. I set it up and charged it and ran it to do the mapping. I then took off the mop plate to have it vacuum. I have a combination of wood, tile, a Persian rug, and some small area rugs. The vacuum doesn't appear to be doing a good job cleaning (leaving dirt behind) and when it goes over the area rugs, it doesn't clean them at all. Lastly, it will go onto the Persian rug in my dining room, but then either gets stuck or has a cliff alert even though it is not that high. I want to be sure I've set everything up correctly, but if this is as good a job as it will do, I will return it. My IRobot cleaned better. Thank you
We're sorry for the inconvenience caused. For the robot leaving dirt behind, may I know where the issue happened? On hardwood floor or on carpet or when it transit from hardwood to rug?
For the issue with the persian rug, may I know if there's any dark patterns on the carpet?
