I've a roborock s5max and the device didn't charge. I tried everything, clean the contacts check the base station etc... nothing worked.
I've found that if I remove the battery for a couple of minutes and plug again the battery the device start to charge to full capacity but once get the 100% the device don't charge anymore... I take the advantage of having again the device with battery to do the cleanings but when we gets again low battery I've to do the same procedure.
Anyone with the same issue? Any clue?
Do you mean the battery level doesn't go up? Does it report any error message?
No errors reported. The battery level doesn't go up... only when I unplug and plug again the battery cable.
Thanks for the response.
If the temperature of the battery is too high, this issue is likely to happen. In this case, please put the robot in a cool and well ventilated area for 2 hours to let it cool down, and then try again to see if the issue will persist.
