I have tried all combinations of button presses with reset on & off dock. Nothing works. Buttons do not respond. I have used this less than 1 month. Very disappointed especially for price I paid.
2. Please hold the power button for around 10 seconds to force shutdown the device and then put the robot on dock to turn itself back on.
3. If neither of the methods can resolve the issue, you may leave the robot alone and to let the battery drain out. Then you may recharge it again to see if it works.
Hello thanks for reaching out.
1. We suggest you factory reset the device.
