Can't figure this problem out. Robot does a good job of cleaning/mopping but it will not automatically empty the dirt bin. The four tabs on the roller are not showing and appears properly installed. Channel to bag is clear. Machine is clear of debris so no blockages.Waste bag is not full. It occasionally will empty but most of the time I have to manually empty the bin. Any suggestions?
same problem and have went through all checks.. roller cover is installed properly too.
The issue you faced may not be solved in a short answer. We hope we could work with you to locate the cause and address it. Would you please contact us at support@roborock.com so that we can better assist?
