I have an E4 and it starts in reverse fine, but when it tries to move forward only one of the wheels turns slightly and then neither of the wheels move. In the rare event the wheels move, once it hits a wall, it won't move forward after it turns. I've checked the unit for debris but the wheen and motors were clear
Thanks for reaching out. Would you pls try the method below to see if it helps?
https://youtu.be/MiBkw_lcTF8
Notice:
