Max 5 not spraying
Max 5 not spraying
My Max 5 just doesn't spray. I've poked a needle through the spray holes and reset the whole thing, nothing. It works well in vacuum mode
  • If water comes out only a little or none at all, please try the methods below.
    1. Make sure the mop cloth is saturated before mopping, install it, and start the robot for 10 minutes with the wet cloth to see if the floor is mopped.
    2. Replace the mop cloth.
    3. Make sure there is no detergent in the water.
    4. Turn the device over, you'll find two small holes under the robot if you remove the water tank. Check if there's anything blocking the hole by poking them slightly with a needle.
    5. Please upgrade your firmware to the latest version.
Susee
