Dyad Pro clean water tank - how to fully empty it?
Is there a secret to getting all of the water out of the clean water tank? The way it's designed inside there isn't a clear path or channel for the water to pour out in the center and so I end up with quite a bit of water left inside. I've been taking a paper towel and using it to soak up the leftovers.
I don't use it every day and don't want the water sitting in it too get moldy.
Indyrobb
