Extra Rooms?
My S7 Max V has mapped rooms that don't exist. Can I manually remove them? It appears that at some point it got turned around and ended up with two rooms mirrored off the front of the house.
  • We are sorry to hear about this issue.
    Unfortunatelly you can't delete those rooms on map directly.
    Would you please add some no-go zones to block those rooms?
    Please then check if the robot will work properly.
lolnope
