Auto empty dock has really high idle power consumption
I have the Roborock S7 in combination with the auto empty dock.
While monitoring the power consumption I noticed that the auto empty dock has a really high idle power consumption.
What i found: when the robot is not on the docking, the power consumption is 0 watts (nice). When the robot enters the dock after cleaning and the dustbin is emptied i monitor around 1200 watts, makes sense. Then the robot starts charging and uses a constant power of around 56 watts until it is fully charged, seems ok to me. But afterwards when the robot is done charging it keeps using around 32 watts at all time, which is quite a lot (almost 0.8kWh a day).
My measurements are in the picture below.
I'm wondering if more people have this problem? is t a known flaw of the roborock system or can i change this with some kind of setting?
Thanks in advance!
Kuiken
