My Roborock s7 is not longer working
yesterday after worked, robot back to the station and after load to 100% did not work again.
  • yesterday after worked, robot back to the station and after load to 100% did not work again. Now is 100% load. When I try to start it again
    it just turns off. The same thing does if I try to empty the container.
    I add a video to show you the problem.
    I also note that if I take the robot out of the load station, I can’t detect the robot in the application. Like if battery is dead. Can you please give me an advice ? Or if robot is complete dead. Best regards
    RR_SupportStaff Member06/12/2023      09:52
    @Efrain:
    The issue you faced may not be solved in a short answer. We hope we could work with you to locate the cause and address it. Would you please contact us at support@roborock.com(if you are in EU, contact support@roborock-eu.com)so that we can better assist? Please also attach the video in the email.
Efrain
