S4 Wheel Module Replacement
Does anyone know if wheel replacements are available for the S4? My left wheel is very difficult to move compared to the right one and I'm getting an internal error when it tries to clean. I see there are replacements for several other models but none of them list the S4 specifically.
  • Please try the method below:
    https://youtu.be/MiBkw_lcTF8
    Notice:
    For wheel replacement, would you please reach out to our support team at support@roborock.com(if you are in EU, contact support@roborock-eu.com) so that we can better assist?
Billy
